[postgis-tickets] [PostGIS] #2460: [raster]: Getting invalid memory access when installing postgis raster in 9.3 (was: Getting invalid memory access when installing postgis raster in 9.3)
trac at osgeo.org
Mon Sep 2 10:52:34 PDT 2013
9.3
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Changes (by robe):
* owner: robe => dustymugs
* component: buildbots => raster
Comment:
okay I rebuilt 9.3rc1 and recompiled and still the same problem. I'm
beginning to suspect something in raster that changed. I'll have to
analyze this on my windows box.
I recompiled 2.1.1dev for 9.3rc1 and the issues does not exist in the
2.1.1dev only in 2.2.0 dev do I get this error.
The sad thing is the error doesn't trigger on winnie (when she's doing the
EDB RC1 tests) at all and earlier 2.2.0dev (like the last one I had
installed don't have this problem). I ruled out extension as the culprit
since if I install with the scripts, I get an error. Both winnie and my
database server are both running windows 2003 R2 64-bit so it doesn't seem
specific to platform. Very frustrating that it is not always
reproducable.
Last time I saw an error like this was when I didn't not have GDAL proj
path set. So part of me is thinking its the introduction of that feature
excp[et I think the iarlier 2.2s I tested with that had this feature were
fine. I'm gong to install and test on my local to see if I can trigger
the issue and where it happens by running each command separately.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2460#comment:5>
