[postgis-tickets] [PostGIS] #2470: travis 2.0 failure on topology regress addlinestring
PostGIS trac at osgeo.org
Thu Sep 5 13:28:19 PDT 2013
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.4
Component:  topology  |     Version:  2.0.x
 Keywords:            |
 I added the yaml and all that other good stuff which now makes travis 2.1
 branch pass.  However 2.0 is failing.  Keep in mind travis is the only one
 testing on  GEOS 3.3.8 so I suspect the issue is a test issue one we've
 already fixed in 2.1.
 https://travis-ci.org/postgis/postgis/builds/11032019
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2470>
