[postgis-tickets] [PostGIS] #2472: Regress failure on debbie testing PostgreSQL 8.4
trac at osgeo.org
Sat Sep 7 03:54:38 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.5
Component: postgis | Version: 2.0.x
Keywords: |
pramsey,
It appears some of your sweeping regress changes don't seem to work on
PostgreSQL 8.4.
PostgreSQL 8.4.17 on x86_64-unknown-linux-gnu, compiled by GCC gcc
(Debian 4.4.5-8) 4.4.5, 64-bit
Postgis 2.0.5SVN - r11943 - 2013-09-06 23:58:06
GEOS: 3.3.10dev-CAPI-1.7.10
PROJ: Rel. 4.7.1, 23 September 2009
Running tests
loader/Point ....................... ok
loader/PointM ....................... ok
loader/PointZ ....................... ok
loader/MultiPoint ....................... ok
loader/MultiPointM ....................... ok
loader/MultiPointZ ....................... ok
loader/Arc ....................... ok
loader/ArcM ....................... ok
loader/ArcZ ....................... ok
loader/Polygon ....................... ok
loader/PolygonM ....................... ok
loader/PolygonZ ....................... ok
loader/TSTPolygon ......... ok
loader/TSIPolygon ......... ok
loader/TSTIPolygon ......... ok
loader/PointWithSchema ..... ok
loader/NoTransPoint ......... ok
loader/NotReallyMultiPoint ............... ok
loader/MultiToSinglePoint ......... ok
loader/ReprojectPts ........ ok
loader/ReprojectPtsGeog ........ ok
loader/Latin1 .... ok
binary .. ok
regress .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_24_diff)
--- regress_expected 2013-09-06 15:57:17.000000000 -0700
+++ /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_24_out
2013-09-06 16:59:20.000000000 -0700
@@ -154,7 +154,7 @@
148|LINESTRING(0 0,5 0,10 0)
149|GEOMETRYCOLLECTION EMPTY
150|SRID=6;GEOMETRYCOLLECTION(POLYGON((0 0,1 0,1 1,0 1,0 0)))
-151|\x01030000000100000005000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000000000000000000000000000000000000000
+151|\001\003\000\000\000\001\000\000\000\005\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000
152|4326
152.1|t
152.2|4326
@@ -167,7 +167,7 @@
159|MULTIPOLYGON EMPTY
160|MULTIPOINT(1 1)
161|MULTILINESTRING((0 0,1 1),(2 2,3 3))
-162|\x010200000003000000f771d98de33826c00000000000004440f771d98de33826c000000000008051400000000000805140f771d98de33826c0
+162|\001\002\000\000\000\003\000\000\000\367q\331\215\3438&\300\000\000\000\000\000\000D@\367q\331\215\3438&\300\000\000\000\000\000\200Q@\000\000\000\000\000\200Q@\367q\331\215\3438&\300
163|POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))
164|POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 1))
ERROR: geometry contains non-closed rings
regress_index .. ok
regress_index_nulls .. ok
lwgeom_regress .. ok
regress_lrs .. ok
removepoint .. ok
setpoint .. ok
simplify .. ok
snaptogrid .. ok
summary .. ok
affine .. ok
empty .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_35_diff)
--- empty_expected 2013-09-06 15:57:17.000000000 -0700
+++ /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_35_out
2013-09-06 16:59:22.000000000 -0700
@@ -23,13 +23,13 @@
T3.16|
T3.17|
T3.18|
-ST_Buffer(empty, tolerance) == empty|\x010300000000000000
-ST_Union(geometry, empty) ==
geometry|\x0103000000010000000400000000000000000000000000000000000000000000000000244000000000000000000000000000001440000000000000144000000000000000000000000000000000
-ST_Union(empty, empty) == empty|\x010300000000000000
-ST_Intersection(geometry, empty) == geometry|\x010300000000000000
-ST_Intersection(empty, empty) == empty|\x010300000000000000
-ST_Difference(geometry, empty) ==
-ST_Difference(empty, geometry) == empty|\x010300000000000000
+ST_Buffer(empty, tolerance) == empty|\001\003\000\000\000\000\000\000\000
+ST_Union(geometry, empty) ==
geometry|\001\003\000\000\000\001\000\000\000\004\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000$@\000\000\000\000\000\000\000\000\000\000\000\000\000\000\024@\000\000\000\000\000\000\024@\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000
+ST_Union(empty, empty) == empty|\001\003\000\000\000\000\000\000\000
+ST_Intersection(geometry, empty) ==
geometry|\001\003\000\000\000\000\000\000\000
+ST_Intersection(empty, empty) ==
+ST_Difference(geometry, empty) ==
+ST_Difference(empty, geometry) ==
ST_Distance(geometry, empty) == NULL|
ST_DWithin(geometry, empty, tolerance) == FALSE|f
ST_Within(geometry, empty) == FALSE|f
measures .. ok
legacy .. ok
long_xact .. ok
ctors .. ok
sql-mm-serialize .. ok
sql-mm-circularstring .. ok
sql-mm-compoundcurve .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_42_diff)
--- sql-mm-compoundcurve_expected 2013-09-06 15:57:17.000000000
-0700
+++ /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_42_out
2013-09-06 16:59:23.000000000 -0700
@@ -66,11 +66,11 @@
public.compoundcurve.the_geom_3dz effectively removed.
public.compoundcurve.the_geom_3dm effectively removed.
public.compoundcurve.the_geom_2d effectively removed.
-valid wkt compound curve
1|\x0109000000020000000102000000030000009fe5797057376340e09398b1b2373bc05aae0a165f0963409f6760a2493d3dc0db6286dfb057634082d8a1b32f843ec0010200000004000000db6286dfb057634082d8a1b32f843ec075b4e4d0c60c634031fa5d1a371540c0d7197ced9b636340a3cb59a7630a41c050f4a72ac0fb6240974769fce3cf41c0
2|\x0109000000010000000102000000060000009fe5797057376340e09398b1b2373bc05aae0a165f0963409f6760a2493d3dc0db6286dfb057634082d8a1b32f843ec075b4e4d0c60c634031fa5d1a371540c0d7197ced9b636340a3cb59a7630a41c050f4a72ac0fb6240974769fce3cf41c0
3|\x0109000000010000000102000000030000000ce586d73cf36240bbc46888f0523bc0102e91c951e76240df90a1bec0f841c0f970c100ffd7624074ade6ce86cd3bc0
4|\x0109000000020000000102000000030000009fe5797057376340e09398b1b2373bc05aae0a165f0963409f6760a2493d3dc0db6286dfb057634082d8a1b32f843ec0010800000005000000db6286dfb057634082d8a1b32f843ec0db6286dfb057634082d8a1b32f843ec075b4e4d0c60c634031fa5d1a371540c0d7197ced9b636340a3cb59a7630a41c050f4a72ac0fb6240974769fce3cf41c0
5|\x010900000003000000010800000003000000468280e724bc6340bf4b46210b973bc0f890aea18d8063402d9664151d483cc0eed64bb6ee726340903ca5bda0863ac0010200000004000000eed64bb6ee726340903ca5bda0863ac09fe5797057376340e09398b1b2373bc05aae0a165f0963409f6760a2493d3dc0db6286dfb057634082d8a1b32f843ec0010800000005000000db6286dfb057634082d8a1b32f843ec0db6286dfb057634082d8a1b32f843ec075b4e4d0c60c634031fa5d1a371540c0d7197ced9b636340a3cb59a7630a41c050f4a72ac0fb6240974769fce3cf41c0
+valid wkt compound curve
1|\001\011\000\000\000\002\000\000\000\001\002\000\000\000\003\000\000\000\237\345ypW7c@\340\223\230\261\2627;\300Z\256\012\026_\011c@\237g`\242I==\300\333b\206\337\260Wc@\202\330\241\263/\204>\300\001\002\000\000\000\004\000\000\000\333b\206\337\260Wc@\202\330\241\263/\204>\300u\264\344\320\306\014c at 1\372]\0327\025@\300\327\031|\355\233cc@\243\313Y\247c\012A\300P\364\247*\300\373b@\227Gi\374\343\317A\300
2|\001\011\000\000\000\001\000\000\000\001\002\000\000\000\006\000\000\000\237\345ypW7c@\340\223\230\261\2627;\300Z\256\012\026_\011c@\237g`\242I==\300\333b\206\337\260Wc@\202\330\241\263/\204>\300u\264\344\320\306\014c at 1\372]\0327\025@\300\327\031|\355\233cc@\243\313Y\247c\012A\300P\364\247*\300\373b@\227Gi\374\343\317A\300
3|\001\011\000\000\000\001\000\000\000\001\002\000\000\000\003\000\000\000\014\345\206\327<\363b@\273\304h\210\360R;\300\020.\221\311Q\347b@\337\220\241\276\300\370A\300\371p\301\000\377\327b at t\255\346\316\206\315;\300
4|\001\011\000\000\000\002\000\000\000\001\002\000\000\000\003\000\000\000\237\345ypW7c@\340\223\230\261\2627;\300Z\256\012\026_\011c@\237g`\242I==\300\333b\206\337\260Wc@\202\330\241\263/\204>\300\001\010\000\000\000\005\000\000\000\333b\206\337\260Wc@\202\330\241\263/\204>\300\333b\206\337\260Wc@\202\330\241\263/\204>\300u\264\344\320\306\014c at 1\372]\0327\025@\300\327\031|\355\233cc@\243\313Y\247c\012A\300P\364\247*\300\373b@\227Gi\374\343\317A\300
5|\001\011\000\000\000\003\000\000\000\001\010\000\000\000\003\000\000\000F\202\200\347$\274c@\277KF!\013\227;\300\370\220\256\241\215\200c at -\226d\025\035H<\300\356\326K\266\356rc@\220<\245\275\240\206:\300\001\002\000\000\000\004\000\000\000\356\326K\266\356rc@\220<\245\275\240\206:\300\237\345ypW7c@\340\223\230\261\2627;\300Z\256\012\026_\011c@\237g`\242I==\300\333b\206\337\260Wc@\202\330\241\263/\204>\300\001\010\000\000\000\005\000\000\000\333b\206\337\260Wc@\202\330\241\263/\204>\300\333b\206\337\260Wc@\202\330\241\263/\204>\300u\264\344\320\306\014c at 1\372]\0327\025@\300\327\031|\355\233cc@\243\313Y\247c\012A\300P\364\247*\300\373b@\227Gi\374\343\317A\300
ERROR: incontinuous compound curve
ERROR: geometry must have an odd number of points
@@ -80,8 +80,8 @@
valid wkb compound curve 4|COMPOUNDCURVE((153.72942375
-27.2175704,152.29285719 -29.23940482,154.74034096
-30.51635287),CIRCULARSTRING(154.74034096 -30.51635287,154.74034096
-30.51635287,152.39926953 -32.16574411,155.11278414
-34.08116619,151.86720784 -35.62414508))
valid wkb compound curve 5|COMPOUNDCURVE(CIRCULARSTRING(157.87950492
-27.59001358,156.01728901 -28.28169378,155.59163966
-26.52589021),(155.59163966 -26.52589021,153.72942375
null response|
-minpoints issues -
pass|\x01090000000100000001020000000200000000000000000000000000000000000000000000000000f03f000000000000f03f
-minpoints issues -
pass|\x010900000001000000010800000003000000000000000000000000000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f
+minpoints issues -
pass|\001\011\000\000\000\001\000\000\000\001\002\000\000\000\002\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?
+minpoints issues -
pass|\001\011\000\000\000\001\000\000\000\001\010\000\000\000\003\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?
ERROR: geometry requires more points
sql-mm-curvepoly .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_43_diff)
--- sql-mm-curvepoly_expected 2013-09-06 15:57:17.000000000 -0700
+++ /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_43_out
@@ -71,11 +71,11 @@
public.curvepolygon.the_geom_3dm effectively removed.
public.curvepolygon.the_geom_3dz effectively removed.
public.curvepolygon.the_geom_4d effectively removed.
-valid wkt curve polygon
1|\x010a00000001000000010200000007000000ccdf061ad9f3614054093e6d99093ec0ab9085dbb6dd614081540229216040c0ebd7a828c33e62409bf026782a7e41c0000000c06bb2624000000020adb440c08e632f616ead6240c9f7b0bf1dd33dc09011eec0de4362407dd6672f76323ec0ccdf061ad9f3614054093e6d99093ec0
2|\x010a00000002000000010200000007000000ccdf061ad9f3614054093e6d99093ec0ab9085dbb6dd614081540229216040c0ebd7a828c33e62409bf026782a7e41c0000000c06bb2624000000020adb440c08e632f616ead6240c9f7b0bf1dd33dc09011eec0de4362407dd6672f76323ec0ccdf061ad9f3614054093e6d99093ec00102000000060000006844c4fe011b6240342e2993e0423fc0d45daf9d93066240c4a0c305d62240c000000080ac31624000000020fbbe40c0000000e0107f6240000000c0a10440c04e1c0c14624c6240bf3fb6405c793fc06844c4fe011b6240342e2993e0423fc0
3|\x010a00000001000000010800000007000000ccdf061ad9f3614054093e6d99093ec0ab9085dbb6dd614081540229216040c0ebd7a828c33e62409bf026782a7e41c0000000c06bb2624000000020adb440c08e632f616ead6240c9f7b0bf1dd33dc09011eec0de4362407dd6672f76323ec0ccdf061ad9f3614054093e6d99093ec0
4|\x010a00000002000000010800000007000000ccdf061ad9f3614054093e6d99093ec0ab9085dbb6dd614081540229216040c0ebd7a828c33e62409bf026782a7e41c0000000c06bb2624000000020adb440c08e632f616ead6240c9f7b0bf1dd33dc09011eec0de4362407dd6672f76323ec0ccdf061ad9f3614054093e6d99093ec00102000000060000006844c4fe011b6240342e2993e0423fc0d45daf9d93066240c4a0c305d62240c000000080ac31624000000020fbbe40c0000000e0107f6240000000c0a10440c04e1c0c14624c6240bf3fb6405c793fc06844c4fe011b6240342e2993e0423fc0
5|\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
+valid wkt curve polygon
1|\001\012\000\000\000\001\000\000\000\001\002\000\000\000\007\000\000\000\314\337\006\032\331\363a at T\011>m\231\011>\300\253\220\205\333\266\335a@\201T\002)!`@\300\353\327\250(\303>b@\233\360&x*~A\300\000\000\000\300k\262b@\000\000\000
\255\264@\300\216c/an\255b@\311\367\260\277\035\323=\300\220\021\356\300\336Cb@}\326g/v2>\300\314\337\006\032\331\363a at T\011>m\231\011>\300
2|\001\012\000\000\000\002\000\000\000\001\002\000\000\000\007\000\000\000\314\337\006\032\331\363a at T\011>m\231\011>\300\253\220\205\333\266\335a@\201T\002)!`@\300\353\327\250(\303>b@\233\360&x*~A\300\000\000\000\300k\262b@\000\000\000
\255\264@\300\216c/an\255b@\311\367\260\277\035\323=\300\220\021\356\300\336Cb@}\326g/v2>\300\314\337\006\032\331\363a at T\011>m\231\011>\300\001\002\000\000\000\006\000\000\000hD\304\376\001\033b at 4.)\223\340B?\300\324]\257\235\223\006b@\304\240\303\005\326"@\300\000\000\000\200\2541b@\000\000\000
\373\276@\300\000\000\000\340\020\177b@\000\000\000\300\241\004@\300N\034\014\024bLb@\277?\266@\\y?\300hD\304\376\001\033b at 4.)\223\340B?\300
3|\001\012\000\000\000\001\000\000\000\001\010\000\000\000\007\000\000\000\314\337\006\032\331\363a at T\011>m\231\011>\300\253\220\205\333\266\335a@\201T\002)!`@\300\353\327\250(\303>b@\233\360&x*~A\300\000\000\000\300k\262b@\000\000\000
4|\001\012\000\000\000\002\000\000\000\001\010\000\000\000\007\000\000\000\314\337\006\032\331\363a at T\011>m\231\011>\300\253\220\205\333\266\335a@\201T\002)!`@\300\353\327\250(\303>b@\233\360&x*~A\300\000\000\000\300k\262b@\000\000\000
5|\001\012\000\000\000\002\000\000\000\001\002\000\000\000\007\000\000\000\314\337\006\032\331\363a at T\011>m\231\011>\300\253\220\205\333\266\335a@\201T\002)!`@\300\353\327\250(\303>b@\233\360&x*~A\300\000\000\000\300k\262b@\000\000\000
\255\264@\300\216c/an\255b@\311\367\260\277\035\323=\300\220\021\356\300\336Cb@}\326g/v2>\300\314\337\006\032\331\363a at T\011>m\231\011>\300\001\011\000\000\000\003\000\000\000\001\010\000\000\000\003\000\000\000hD\304\376\001\033b at 4.)\223\340B?\300\324]\257\235\223\006b@\304\240\303\005\326"@\300\000\000\000\200\2541b@\000\000\000
\373\276@\300\001\002\000\000\000\002\000\000\000\000\000\000\200\2541b@\000\000\000
\373\276@\300\000\000\000\340\020\177b@\000\000\000\300\241\004@\300\001\010\000\000\000\003\000\000\000\000\000\000\340\020\177b@\000\000\000\300\241\004@\300N\034\014\024bLb@\277?\266@\\y?\300hD\304\376\001\033b at 4.)\223\340B?\300
sql-mm-general .. ok
sql-mm-multicurve .. ok
sql-mm-multisurface .. ok
polyhedralsurface .. ok
polygonize .. ok
postgis_type_name .. ok
out_geometry .. ok
out_geography .. ok
in_gml .. ok
in_kml .. ok
iscollection .. ok
regress_ogc .. ok
regress_ogc_cover .. ok
regress_ogc_prep .. ok
regress_bdpoly .. ok
regress_proj .. ok
regress_management .. ok
dump .. ok
dumppoints .. ok
wmsservers .. ok
wkt .. ok
wkb .. ok
tickets .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_66_diff)
--- tickets_expected 2013-09-06 15:57:17.000000000 -0700
+++ /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_66_out
2013-09-06 16:59:27.000000000 -0700
@@ -23,7 +23,7 @@
#122|CIRCULARSTRING(220268 150415,220227 150505,220227 150406)
#124a|COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30
5),CIRCULARSTRING(30 5,34 56,67 89))
-#145a|\x0103000020e610000000000000
+#145a|\001\003\000\000 \346\020\000\000\000\000\000\000
#145b|0
#146|0|t|GEOMETRYCOLLECTION(LINESTRING(0 0,-1 -1),MULTIPOINT(1 2,2 3))
ERROR: Invalid hex string, length (267) has to be a multiple of two!
@@ -47,7 +47,7 @@
#213|17
#234|COMPOUNDCURVE((0 0,1 1))
#241|0
-#254|\x010700000000000000
+#254|\001\007\000\000\000\000\000\000\000
#259|
#260|1667701
#261|0
@@ -105,8 +105,8 @@
#681e|
#681f|
#681g|
-#682|\x0103000020e610000000000000
-#683|\x0103000020e610000000000000
+#682|\001\003\000\000 \346\020\000\000\000\000\000\000
+#683|\001\003\000\000 \346\020\000\000\000\000\000\000
#684,#2109|SRID=4326;POINT EMPTY
#2109|SRID=3395;POINT EMPTY
#685|0103000020E610000000000000
@@ -115,18 +115,18 @@
#689|f
#690
010200000003000000F771D98DE33826C00000000000004440F771D98DE33826C000000000008051400000000000805140F771D98DE33826C0
-#693a|\x0103000060e61000000100000005000000ea95b20c71c851c02b1895d409204540000000000000f03f9cc420b072c851c0c7bab88d062045400000000000000840b1506b9a77c851c08e75711b0d20454000000000000000c0ff21fdf675c851c0f2d24d6210204540000000000000f03fea95b20c71c851c02b1895d4092045400000000000000000
-#693b|\x0103000060e61000000100000007000000ea95b20c71c851c0aa605452272045400000000000000000386744696fc851c04703780b2420454000000000000034408638d6c56dc851c04703780b2420454000000000000034c08638d6c56dc851c0e3a59bc42020454000000000000014408638d6c56dc851c08048bf7d1d20454000000000000010409cc420b072c851c04703780b242045400000000000001840ea95b20c71c851c0aa605452272045400000000000003e40
+#693a|\001\003\000\000`\346\020\000\000\001\000\000\000\005\000\000\000\352\225\262\014q\310Q\300+\030\225\324\011
E@\000\000\000\000\000\000\360?\234\304 \260r\310Q\300\307\272\270\215\006
E@\000\000\000\000\000\000\010@\261Pk\232w\310Q\300\216uq\033\015
E@\000\000\000\000\000\000\000\300\377!\375\366u\310Q\300\362\322Mb\020
E@\000\000\000\000\000\000\360?\352\225\262\014q\310Q\300+\030\225\324\011
E@\000\000\000\000\000\000\000\000
+#693b|\001\003\000\000`\346\020\000\000\001\000\000\000\007\000\000\000\352\225\262\014q\310Q\300\252`TR'
E@\000\000\000\000\000\000\000\0008gDio\310Q\300G\003x\013$
E@\000\000\000\000\000\0004@\2068\326\305m\310Q\300G\003x\013$
E@\000\000\000\000\000\0004\300\2068\326\305m\310Q\300\343\245\233\304
E@\000\000\000\000\000\000\024@\2068\326\305m\310Q\300\200H\277}\035
E@\000\000\000\000\000\000\020@\234\304 \260r\310Q\300G\003x\013$
E@\000\000\000\000\000\000\030@\352\225\262\014q\310Q\300\252`TR'
E@\000\000\000\000\000\000>@
#694
ERROR: Shell is not a line
#695
ERROR: First argument must be a LINESTRING
-#696|\x010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
+#696|\001\017\000\000\200\006\000\000\000\001\003\000\000\200\001\000\000\000\005\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\001\003\000\000\200\001\000\000\000\005\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\001\003\000\000\200\001\000\000\000\005\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\001\003\000\000\200\001\000\000\000\005\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\001\003\000\000\200\001\000\000\000\005\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\001\003\000\000\200\001\000\000\000\005\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?\000\000\000\000\000\000\360?\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\360?
#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
11028513.63)
-#723|\x0101000020e61000006284f068e33826c00000000000004440
-#723|\x0107000020e610000000000000
-#723|\x0101000020e61000006284f068e33826c00100000000804b40
+#723|\001\001\000\000
\346\020\000\000b\204\360h\3438&\300\000\000\000\000\000\000D@
+#723|\001\007\000\000 \346\020\000\000\000\000\000\000
\346\020\000\000b\204\360h\3438&\300\001\000\000\000\000\200K@
#804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos
srsDimension="2">0 0</gml:pos></gml:Point>
#845|t
#834|GEOMETRYCOLLECTION(POINT(0 0 5),LINESTRING(10 10 5,10 0 5))
@@ -182,7 +182,7 @@
#1453.2|f
#1454|t
#1414|CURVEPOLYGON Z EMPTY
-#1478|\x01040000200100000000000000
+#1478|\001\004\000\000 \001\000\000\000\000\000\000\000
#745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
#1450|POINT|POLYGON
#1482|4326
@@ -217,7 +217,7 @@
#1697.2|0
#1697.3|1024
#1734.1|1026
-#1755|\x01e9030000000000000040554000000000008041400000000000000000
+#1755|\001\351\003\000\000\000\000\000\000\000 at U@\000\000\000\000\000\200A@\000\000\000\000\000\000\000\000
#1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
#1791|4.7
ERROR: ST_Segmentize: invalid max_distance 0 (must be >= 0)
typmod .. ok
remove_repeated_points .. ok
split .. ok
relate .. ok
bestsrid .. ok
concave_hull .. ok
hausdorff .. ok
regress_buffer_params .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
sharedpaths .. ok
snap .. ok
node .. ok
unaryunion .. ok
clean .. ok
relate_bnr .. ok
in_geojson .. ok
uninstall .. ok (3699)
Run tests: 85
Failed: 5
Seems to be the difference in bytea that PostgreSQL 9.0 default to hex and
8.4 is escape. We might need to set as an extra flag I guess for 2.0
testing. 2.1+ is a non-issue since the minimum we support in 2.1 is 9.0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2472>
