[postgis-tickets] [PostGIS] #2476: Invalid access to memory location in postgis-2.0.dll (windows 64-bit) 9.3 rc1
PostGIS trac at osgeo.org
Mon Sep 9 18:27:28 PDT 2013
rc1
 Reporter:  robe          |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:  PostGIS 2.1.1
Component:  postgis       |     Version:  2.1.x
 Keywords:  windows64bit  |
 this is the same error I was getting during install that magically went
 away. I'm getting this on some raster tables.
 "POSTGIS="2.1.1dev r11897" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER"
 error getting which is only on access to certain raster tables (MA state
 plane meters)
 An error has occurred:
 ERROR:  could not load library "C:/Program
 Files/PostgreSQL/9.3/lib/postgis-2.1.dll": Invalid access to memory
 location.
 What is very bothersome is that I'm only having this issue on my 64-bit
 windows 7 laptop.  I'm going to try a newer build to see if the problem
 goes away. My windows 7 is running postgis 2.2.0 dev.  The tables in
 question are ones that I couldn't load from file because it GDAL_DATA was
 not set though I verified it was set and then on last file for load it
 would crash raster2pgsql with same message.  My next attempt was to
 restore from my postgis 2.2.0dev build but tables when accessed then gave
 same message.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2476>
