[postgis-tickets] [PostGIS] #2476: Invalid access to memory location in postgis-2.0.dll (windows 64-bit) 9.3 rc1
PostGIS trac at osgeo.org
Mon Sep 9 18:30:14 PDT 2013
rc1
 Reporter:  robe          |       Owner:  robe
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:  PostGIS 2.1.1
Component:  raster        |     Version:  2.1.x
 Keywords:  windows64bit  |
Description changed by robe:
Old description:
> this is the same error I was getting during install that magically went
> away. I'm getting this on some raster tables.
> "POSTGIS="2.1.1dev r11897" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel.
> 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24"
> LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER"
> error getting which is only on access to certain raster tables (MA state
> plane meters)
> An error has occurred:
> ERROR:  could not load library "C:/Program
> Files/PostgreSQL/9.3/lib/postgis-2.1.dll": Invalid access to memory
> location.
> What is very bothersome is that I'm only having this issue on my 64-bit
> windows 7 laptop.  I'm going to try a newer build to see if the problem
> goes away. My windows 7 is running postgis 2.2.0 dev.  The tables in
> question are ones that I couldn't load from file because it GDAL_DATA was
> not set though I verified it was set and then on last file for load it
> would crash raster2pgsql with same message.  My next attempt was to
> restore from my postgis 2.2.0dev build but tables when accessed then gave
> same message.
New description:
 "POSTGIS="2.1.1dev r11897" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 plane meters)
 location.
 goes away. My windows 7 desktop is running postgis 2.2.0 dev.  The tables
 in question are ones that I couldn't load from file on my laptop because
 it complained GDAL_DATA was not set though I verified it was set and then
 on last file for load it would crash raster2pgsql with same message.  My
 next attempt was to restore from my postgis 2.2.0dev build but tables when
 accessed then gave same message.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2476#comment:3>
