[postgis-tickets] [PostGIS] #2485: [raster]: SQL functions namespace qualification (was: SQL functions namespace qualification)
trac at osgeo.org
Mon Sep 23 08:32:11 PDT 2013
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.5
Component: raster | Version: 2.0.x
Keywords: |
Changes (by robe):
* owner: pramsey => dustymugs
* component: postgis => raster
* milestone: => PostGIS 2.0.5
Comment:
this will be difficult to do since people install postgis in different
schemas and enforcing a particular schema will be hard without causing
more damage.
This issue you describe is only an issue for functions that call other
functions. The backup schema qualifies the constraint functions, so its
the fact that this constraint function calls another function that is the
problem. I've had similar issue when using ST_Transform on indexes that
my indexes don't come back unless I add a search path to the ST_Transform
function.
Bborie and Pierre,
Is there any way to make this constraint function not call
ST_BandMetaData? That is ultimately the issue. I've flagged this as a
raster issue since I don't think we have any functions in PostGIS
geometry/geography that are used in constraints and call other functions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:1>
