[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
trac at osgeo.org
Mon Sep 23 11:12:02 PDT 2013
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.5
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Ah... so not the actual function used in the constraint but rather
functions within the constraint functions.
I don't understand your second paragraph. The data has no constraints, the
table does. If you're restoring data to a table with no constraints, there
is nothing to go wrong.
If you're doing a standard pg_dump/pg_restore cycle, I've never seen where
the data would be restored before the table structure...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:12>
