[postgis-tickets] [PostGIS] #2417: pgsql2shp doesnt see SRID
PostGIS trac at osgeo.org
Wed Sep 25 08:59:17 PDT 2013
  Reporter:  darkblueb      |       Owner:  strk
      Type:  defect         |      Status:  new
  Priority:  medium         |   Milestone:  PostGIS 2.1.1
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:                 |    Keywords:  srid, pgsql2shp
Changes (by robe):
  * owner:  robe => strk
  * component:  documentation => loader/dumper
Comment:
 strk,
 I'm switching this ticket over to you since you feel so strongly about it.
 Like I said the only time where this is an issue is if you load up a table
 that has no constraints OR typmod, which would result in a table
 incorrectly registered in geometry_columns or of mixed SRID. If it finds
 no record in geometry_columns (such as the case with passing an SQL
 statement, it already inspects it.
 So for me I have no itch here to scratch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2417#comment:12>
