[postgis-tickets] [PostGIS] #2440: Remove warnings from functions deprecated in 2.1.0
trac at osgeo.org
Fri Sep 27 10:18:12 PDT 2013
Reporter: realityexists | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.1
Component: postgis | Version: 2.1.x
Resolution: fixed | Keywords:
Comment(by realityexists):
If this the above is too hard then I'd suggest a 3-stage approach:
Release N adds a DEBUG message, ie. "you should start thinking about
fixing it, but you still have time"
Release N+1 change it to a WARNING message, ie. "you really should fix
this now"
Release N+2 removes the function
This way, even if nobody saw the DEBUG message and developers didn't
become aware of the deprecation until release N+1, they can still change
the code straight-away as long as all the users are no more than 1 major
version behind (release N).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2440#comment:12>
