[postgis-tickets] [PostGIS] #2872: make install builds documentation
trac at osgeo.org
Tue Aug 5 05:56:11 PDT 2014
Reporter: gdt | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.4
Component: build/upgrade/install | Version: 2.0.x
Keywords: |
make should perform all building steps, and make install should only copy
(via "install") files to ${DESTDIR}, with an exception for libtool to
relink binaries/libraries that had been pointing at libraries in the
workding directory.
To repeat, run make as a non-root user, and make install as root, and look
for root-written files in the working directory, as well as observing
build commands in the log.
This isn't incredibly serious, but could be cause for packaging systems to
reject postgis.
I definitely just saw this, but now can't reproduce. Anyone else?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2872>
