[postgis-tickets] [PostGIS] #2880: cu_varint warnings and lwout_twkb.c warnings
trac at osgeo.org
Fri Aug 8 06:35:03 PDT 2014
Reporter: robe | Owner: nicklas
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Old description:
> cu_varint.c
> cu_varint.c: In function 'do_test_u32_varint':
> cu_varint.c:30:2: warning: implicit declaration of function
> 'varint_u32_encoded_size' [-Wimplicit-function-declaration]
> size = varint_u32_encoded_size(nr);
> cu_varint.c:35:2: warning: implicit declaration of function
> 'varint_u32_encode_buf' [-Wimplicit-function-declaration]
> varint_u32_encode_buf(nr, buf);
> cu_varint.c: In function 'do_test_s32_varint':
> cu_varint.c:50:2: warning: implicit declaration of function
> 'varint_s32_encoded_size' [-Wimplicit-function-declaration]
> size = varint_s32_encoded_size(nr);
> cu_varint.c:55:2: warning: implicit declaration of function
> 'varint_s32_encode_buf' [-Wimplicit-function-declaration]
> varint_s32_encode_buf(nr, buf);
> cu_varint.c: In function 'do_test_u64_varint':
> cu_varint.c:70:2: warning: implicit declaration of function
> 'varint_u64_encoded_size' [-Wimplicit-function-declaration]
> size = varint_u64_encoded_size(nr);
> cu_varint.c:75:2: warning: implicit declaration of function
> 'varint_u64_encode_buf' [-Wimplicit-function-declaration]
> varint_u64_encode_buf(nr, buf);
> cu_varint.c: In function 'do_test_s64_varint':
> cu_varint.c:90:2: warning: implicit declaration of function
> 'varint_s64_encoded_size' [-Wimplicit-function-declaration]
> size = varint_s64_encoded_size(nr);
> cu_varint.c:95:2: warning: implicit declaration of function
> 'varint_s64_encode_buf' [-Wimplicit-function-declaration]
> varint_s64_encode_buf(nr, buf);
> cu_varint.c: In function 'test_varint':
> cu_varint.c:154:2: warning: this decimal constant is unsigned only in ISO
> C90 [enabled by default]
> do_test_s32_varint(-2147483648, 5, "FFFFFFFF0F");
New description:
cu_varint.c
Comment(by strk):
Should be fixed by r12874
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2880#comment:3>
