[postgis-tickets] [PostGIS] #2889: [raster]: warning rt_pg_error suggestion by compiler to use gnu_printf
trac at osgeo.org
Sat Aug 9 22:35:12 PDT 2014
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.0
Component: raster | Version: 2.1.x
Keywords: |
Not quite sure if we want to do anything about this. Saw it in 9.5 dev
build but didn't check other builds. Just mark as wontfix if you think
its not needed.
rtpostgis.c: In function ‘rt_pg_error’:
rtpostgis.c:479: warning: function might be possible candidate for
‘gnu_printf’ format attribute
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2889>
