[postgis-tickets] [PostGIS] #2898: Define a guideline for function cost
PostGIS trac at osgeo.org
Fri Aug 15 08:52:44 PDT 2014
 Reporter:  strk         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Alright so in the light of the new findings, sliced detoasting (header
 only) and full detoasting do not make such a big difference. It is
 detoasting itself that hurts. Guidelines should then not take that part
 much in consideration, other than a COST offset common to each and every
 function.
 Besides, I suspect that the planner should be considering cost of
 detoasting on itself, as the same function could be invoked with the input
 already detoasted...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2898#comment:4>
