[postgis-tickets] [PostGIS] #2904: documentation on ST_3DIntersects is misleading
trac at osgeo.org
Fri Aug 22 23:38:33 PDT 2014
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.4
Component: documentation | Version: trunk
Keywords: |
http://postgis.net/docs/manual-dev/ST_3DIntersects.htmlI
t's also wrong. It says it only support linestrings but supports others
with caveats.
It also doesn't reflect what happens when sfcgal is enabled as backend.
I suspect for sfcgal for closed surfaces it treats them as volumes, but
then again not absolutely sure.
See stackoverflow user comment
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2904>
