[postgis-tickets] [PostGIS] #2905: Ensure that raster_columns is always readable by public unless explicitly made unreadable
PostGIS trac at osgeo.org
Tue Aug 26 03:19:00 PDT 2014
made unreadable
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.1.4
Component:  raster  |     Version:  2.1.x
 Keywords:          |
Comment(by strk):
 Another idea would be that some function is made available to check the
 state of installation. Right now only "postgis_full_version" does some of
 that, warning if you're out of sync between library and scripts, maybe the
 same function could also check permissions and warn you about that ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2905#comment:3>
