[postgis-tickets] [PostGIS] #2908: Cannot upgrade: cannot drop function st_summarystats(raster, integer, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Tue Aug 26 07:35:41 PDT 2014
st_summarystats(raster,integer,boolean) because other objects depend on it
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:  raster                 |
Comment(by strk):
 Alright, the return datatype changed, which is the reason why the function
 is dropped.
 BUT, we should make the drop dependent on source version, driven by
 postgis_proc_upgrade.pl.
 When a function signature changed in an way that is not compatible with
 "CREATE OR REPLACE FUNCTION", we should note it with a "Last Something"
 documenting the incompatibility.
 See also #2722
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2908#comment:2>
