[postgis-tickets] [PostGIS] #2556: geography ST_Intersects results depending on insert order
trac at osgeo.org
Sun Feb 2 07:15:52 PST 2014
Reporter: gekorob | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: st_intersects intersection geography |
Comment(by robe):
I've confirmed same issue with original ticket example so the two are the
same issue.
SELECT id, _ST_DistanceUnCached(extent, geog) As uncached_dist,
ST_Distance(extent,geog) As dist,
_ST_DistanceUncached(ST_Boundary(extent::geometry)::geography,
ST_Boundary(geog::Geometry)::geography) As bounddist
from images CROSS JOIN st_geogfromtext('SRID=4326;POLYGON((-46.625977
81.634149,-46.625977 81.348076,-48.999023 81.348076,-48.999023
81.634149,-46.625977 81.634149))') As geog;
id | uncached_dist | dist | bounddist
47409 | 20623.2731762032 | 20623.273176203 | 20623.2731762032
1 | 0 | 16361.577605712 | 16361.5776057123
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2556#comment:9>
