[postgis-tickets] [PostGIS] #2422: geography regression difference ST_DWithin
PostGIS trac at osgeo.org
Mon Feb 3 21:43:03 PST 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.1.2
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by robe):
 Some sort of floating point abberation with converting to radians:
 SELECT gid, _ST_DWithin(geog, tgeog, 1600,true )
 , ST_Distance(geog, tgeog) , _ST_DistanceUnCached(geog, tgeog) As
 uncached_dist
 FROM  dwithgeogbug CROSS JOIN ST_GeogFromText('POINT(-69.83262 43.43636)')
 As tgeog;
  gid | _st_dwithin |  st_distance   |  uncached_dist
    1 | t           | 1400.230346843 | 1400.23034684253
    2 | t           | 1005.627279769 | 1005.62727976866
 SELECT gid, _ST_DWithin(geog, tgeog, 1609,true )
 uncached_dist
 As tgeog;
    2 | f           | 1005.627279769 | 1005.62727976866
 how can a bigger radius result in false when a smaller radius results in
 true
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2422#comment:33>
