[postgis-tickets] [PostGIS] #2422: geography regression difference ST_DWithin
trac at osgeo.org
Mon Feb 3 22:31:44 PST 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by pramsey):
Probably "fixed" at r12214, (see comment).
If fix confirmed, also needs port to trunk, but precise test case needs to
be stripped out to be brought into CUnit and debugged in detail, is likely
a subtle failure in the tree-on-tree distance code when used with
tolerances.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2422#comment:35>
