[postgis-tickets] [PostGIS] #2422: geography regression difference ST_DWithin
trac at osgeo.org
Tue Feb 4 06:09:02 PST 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by robe):
okay that seems to fix the issue but like you said its just a bandage
doesn't solve your underlying no?
I have dwithinbug_data.sql attached above in case you didn't notice but
the geometry that was failing in that dataset has 197 points. You think
that's too big to stuff in cunit?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2422#comment:36>
