[postgis-tickets] [PostGIS] #2613: st_curvetoline not accurate
trac at osgeo.org
Tue Feb 4 13:55:42 PST 2014
Reporter: hassony | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.5
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by pramsey):
I'm not seeing the same effect here (osx 10.9, clang, pgsql 9.2).
with curve as (
select st_curvetoline(
'CURVEPOLYGON(CIRCULARSTRING(-192.63 96.09,-236.72 -84.3,-262.33
-256.89,-267.71 -409.94,-252.5 -533,-217.73 -617.69,-165.78
-658.24,-100.19 -651.89, -25.42 -599.06,53.44 -503.37,130.99
-371.32,201.97 -211.92,261.53 -36.04,305.62 144.35,331.23 316.94,336.61
469.99,321.4 593.05,286.64 677.74,234.69 718.29,169.09 711.94,94.32
659.11,15.47 563.42,-62.09 431.37,-133.07 271.98,-192.63 96.09))'
) as curve ),
startend as (
select
st_y(st_startpoint(st_exteriorring(curve))) as s,
st_y(st_endpoint(st_exteriorring(curve))) as e
from curve )
select s = e from startend;
And in reviewing the code, line 234 in lwsegmentize.c actually adds the
first coordinate of the original line without alteration to the
segmentized version. So I cannot even see programmatically how coordinate
drift could be introduced. Any further examples? Smaller ones?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2613#comment:1>
