[postgis-tickets] [PostGIS] #2627: st_linetocurve() pta_desegmentize needs implementation for npoints < 4
trac at osgeo.org
Wed Feb 5 00:55:57 PST 2014
Reporter: mjurce | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.5
Component: postgis | Version: 2.0.x
Keywords: curves |
Comment(by mjurce):
What about http://trac.osgeo.org/postgis/ticket/2464
The error parameter could be the max distance between the segment and the
arc:
build the arc then check the distance against the linear segment.
Cast to arc if distance low ( to be specified ).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2627#comment:8>
