[postgis-tickets] [PostGIS] #2464: st_curvetoline maxError instead of segments/quarter paramter
PostGIS trac at osgeo.org
Sun Feb 9 02:04:27 PST 2014
 Reporter:  mjurce       |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:  curves       |
Comment(by mjurce):
 The maxError " maxDist(chord,arc) with n points segmentation could be
 computed:
 maxError=r*(1-cos( theta/(2*(n+1)) ) )
 Solving for "maxError" should give:
 nPoints = theta/(2*acos(1- maxError/r))
 Someone could check if this is correct?
 Then is easy to plug-in into arc segmentizer.
 The angle increment will be given from this formula.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2464#comment:3>
