[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
PostGIS trac at osgeo.org
Sat Feb 22 19:59:56 PST 2014
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by robe):
 Yap this breaks extensions in way I expected it would.  To test I did:
 1) before installing new binaries etc:
 CREATE EXTENSION postgis VERSION "2.1.2dev"
 2) then upgrade to postgis-2.1.2
 ALTER EXTENSION postgis UPDATE TO "2.1.2devnext";
 3) Then to see what was left behind:
 CREATE SCHEMA postgis;
 ALTER EXTENSION postgis SET SCHEMA postgis;
 And whammo the only aggregates that moved over to the postgis schema are
 the raster aggregates.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:19>
