[postgis-tickets] [PostGIS] #2652: Add --version switch to run_test.pl
PostGIS trac at osgeo.org
Sun Feb 23 08:39:26 PST 2014
 Reporter:  strk         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 The switch could be used to determine target install version for installs
 and upgrades. The current target version for non-extension run is whatever
 is found in the staged install, and same for upgrade.
 For extension the target is the last-installed version and the upgrade is
 with "next" appended.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2652>
