[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
trac at osgeo.org
Sun Feb 23 10:47:17 PST 2014
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: build/upgrade/install | Version: 2.1.x
Keywords: |
Comment(by strk):
No problem, I was under the "hack fever" spell.
Failure I was getting was reported as #2651
The make check options are really not new: RUNTESTFLAGS env variable will
be used to pass switches to run_test.pl, available switches can be seen
running it with no arguments.
I've only "fixed" --upgrade when used togheter with --extension to really
use the extension-oriented upgrade procedure.
Looking forward for your test results.
Note that the extension upgrades are still being inferior to straight
scripts in that they don't distinguish between minor and micro updates, so
they might drop/recreate more than they should.
That part I hadn't touched (the Makefile was too crowded for me to touch
w/out rewriting completely ;)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:30>
