[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
trac at osgeo.org
Mon Feb 24 00:27:25 PST 2014
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: build/upgrade/install | Version: 2.1.x
Keywords: |
Comment(by strk):
See how you like r12271.
With that commit the _upgrade_* scripts should be back to all being the
same, no matter which version we come from, because the version is checked
by the script itself (in plpgsql).
This worked fine:
run_test.pl --extension --upgrade ticket.sql
I guess you know how to test better...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:36>
