[postgis-tickets] [PostGIS] #2986: [raster] raster2pgqsql
trac at osgeo.org
Thu Nov 6 00:07:11 PST 2014
Reporter: rmorelli | Owner: dustymugs
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.5
Component: raster | Version: 2.1.x
Keywords: |
I've been dealing with loading a bunch of rasters in a table using -F
option.
When coming to play with mapserver postgis raster LAYER definition(s) (ie
DATA statement) I've found that using WHERE clause on the "filename" field
is really a mess because escaping doesn't work (1).
Querying an integer data type field (as in the 2nd example in
http://postgis.net/docs/RT_FAQ.html#idp61699792) works smoothly.
So, could you consider adding a cli option in order to add a new column of
integer data type? Maybe casting filename (text) into id (int)?
eg. my workaround has been: adding a new integer column and then use
"UPDATE raster.dem SET id=CAST(substring(filename FROM '_(.*?)\.') AS
integer);"
Hope this was clear.
Regards
Raffaele
PS really don't know if this should be also reported to mapserver devs,
anyway knwoledge is useful.
(1)
DATA "PG:host=localhost port=5432 dbname='xxx' user='xxx' password='xxx'
schema='raster' table='dem' where='filename=\'dem20_12.tif\'' mode='2'"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2986>
