[postgis-tickets] [PostGIS] #2991: ST_Transform using PROJ.4 strings
PostGIS trac at osgeo.org
Mon Nov 10 15:08:56 PST 2014
 Reporter:  mwtoews      |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS Future
Component:  postgis      |     Version:
 Keywords:               |
 The idea behind this enhancement is to directly use a PROJ.4 string to
 transform to/from, rather than looking up `proj4text` in `spatial_ref_sys`
 using a SRID.
 There are an infinite number of possible projections that can be described
 with a PROJ.4 string, such as projections centred on a particular geometry
 used to perform an equidistant spatial analysis. It could also be useful
 to fine-tune a `proj4text` before assigning it an SRID in
 `spatial_ref_sys`.
 Here are some ideas for the SQL signatures:
 ST_Transform(geometry g, text to_proj, text from_proj) RETURNS geometry;
 ST_Transform(geometry g, text to_proj, integer from_srid DEFAULT NULL)
 RETURNS geometry;
 ST_Transform(geometry g, integer to_srid, text from_proj) RETURNS
 geometry;
 Only the last signature would return a geometry with an SRID from
 `spatial_ref_sys`; all others would return a geometry with undefined SRID
 (0). With the second signature, if `from_srid` is NULL, then the SRID is
 obtained from the geometry, and an error is raised if it is undefined.
 Any thoughts? Do these signatures cover everything, or are there potential
 clashes?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2991>
