[postgis-tickets] [PostGIS] #2992: winnie regress failures on raster tests
trac at osgeo.org
Fri Nov 14 12:55:29 PST 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
I don't think this has anything to do with PostGIS raster. These tests
started failing on winnie around the time of changes in interrupt
(November 11th). Unfortunately I must have set to not store history that
far. I'm suspecting some sort of warnings level got changed:
Note how all the errors are because "DO" is not being stripped.
Running tests
check_gdal .. ok
load_outdb ... ok
check_raster_columns .. ok
check_raster_overviews .. ok
rt_io .. ok
rt_bytea .. ok
box3d .. ok
rt_addband .. ok
rt_band .. ok
rt_tile .. ok
rt_dimensions .. ok
rt_scale .. ok
rt_pixelsize .. ok
rt_upperleft .. ok
rt_rotation .. ok
rt_georeference .. ok
rt_set_properties .. ok
rt_isempty .. ok
rt_hasnoband .. ok
rt_metadata .. ok
rt_rastertoworldcoord .. ok
rt_worldtorastercoord .. ok
rt_convexhull .. ok
rt_envelope .. ok
rt_band_properties .. ok
rt_set_band_properties .. ok
rt_pixelaspolygons .. ok
rt_pixelaspoints .. ok
rt_pixelascentroids .. ok
rt_setvalues_array .. ok
rt_summarystats .. ok
rt_count .. ok
rt_histogram .. ok
rt_quantile .. ok
rt_valuecount .. ok
rt_valuepercent .. ok
rt_bandmetadata .. ok
rt_pixelvalue .. ok
rt_neighborhood .. ok
rt_nearestvalue .. ok
rt_pixelofvalue .. ok
rt_polygon .. ok
rt_utility .. ok
rt_fromgdalraster .. ok
rt_asgdalraster .. ok
rt_astiff .. ok
rt_asjpeg .. ok
rt_aspng .. ok
rt_reclass .. ok
rt_gdalwarp .. ok
rt_asraster .. ok
rt_dumpvalues .. ok
rt_createoverview .. ok
rt_mapalgebraexpr .. ok
rt_mapalgebrafct .. ok
rt_mapalgebraexpr_2raster .. ok
rt_mapalgebrafct_2raster .. ok
rt_mapalgebrafctngb .. ok
rt_mapalgebrafctngb_userfunc .. ok
rt_intersection .. ok
rt_clip .. ok
rt_mapalgebra .. failed (diff expected obtained:
/projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_62_diff)
--- rt_mapalgebra_expected 2014-11-11 06:03:25 -0500
/projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_62_out
2014-11-13 15:26:52 -0500
@@ -125,6 +125,7 @@
NOTICE: pos = [0:1][1:2]={{2,2},{4,4}}
NOTICE: userargs = {1000}
NOTICE: record = (17,"(2,-4,2,2,1,-1,0,0,0,1)","(32BUI,0,f,)",1000)
+DO
NOTICE: value = {{{1}},{{2}}}
NOTICE: pos = [0:2][1:2]={{1,1},{2,2},{1,1}}
NOTICE: userargs = <NULL>
rt_mapalgebra_expr .. ok
rt_mapalgebra_mask .. ok
rt_union .. ok
rt_invdistweight4ma .. ok
rt_4ma .. ok
rt_setvalues_geomval .. ok
rt_elevation_functions .. failed (diff expected obtained:
/projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_69_diff)
--- rt_elevation_functions_expected 2014-11-11 06:03:25 -0500
/projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_69_out
2014-11-13 15:26:54 -0500
@@ -1,3 +1,4 @@
+DO
0|aspect|1|1|315.000000
0|aspect|2|1|341.565063
0|aspect|3|1|0.000000
rt_colormap .. ok
rt_gist_relationships .. ok
rt_intersects .. ok
rt_samealignment .. ok
rt_geos_relationships .. ok
rt_iscoveragetile .. ok
bug_test_car5 .. ok
permitted_gdal_drivers .. failed (diff expected obtained:
/projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_77_diff)
--- permitted_gdal_drivers_expected 2014-11-11 06:03:25 -0500
/projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_77_out
2014-11-13 15:26:57 -0500
@@ -1,3 +1,4 @@
+DO
4326
ERROR: RASTER_fromGDALRaster: Could not open bytea with GDAL. Check that
the bytea is of a GDAL supported format
ERROR: rt_band_load_offline_data: Cannot open offline raster:
<VRTDataset rasterXSize="1000" rasterYSize="1"><VRTRasterBand band="1"
subClass="VRTRawRasterBand"><SourceFilename>/etc/passwd</SourceFilename></VRTRasterBand></VRTDataset>
tickets .. ok
loader/Basic .... ok
loader/Projected ..... ok
loader/BasicCopy .... ok
loader/BasicFilename .... ok
loader/BasicOutDB .... ok
loader/Tiled10x10 .... ok
loader/Tiled10x10Copy .... ok
loader/Tiled8x8 .... ok
clean .. ok
uninstall . /projects/postgis/branches/2.2/regress/00-regress-
install/share/contrib/postgis/uninstall_rtpostgis.sql
install/share/contrib/postgis/uninstall_postgis.sql
. ok (4336
Run tests: 88
Failed: 3
I'm getting this in the diff files for example:
@@ -1,3 +1,4 @@
+DO
4326
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2992>
