[postgis-tickets] [PostGIS] #2992: winnie regress failures on raster tests
PostGIS trac at osgeo.org
Fri Nov 14 13:45:22 PST 2014
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 nope she is already doing an svn clean.  I'm going to change your regex
 script after I have done some testing.
 I'm guessing your
   @lines = grep(!/^(DO)$/, @lines);
 Doesn't work on windows presumably because of the line break difference or
 something so as far as windows is concerned (or at least running under
 mingw), DO is not the only thing on the line.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2992#comment:3>
