#2965: ST_Distance, use_spheroid default
Reporter: gitai | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.5
Component: postgis | Version: 2.1.x
Keywords: ST_Distance, use_spheroid |
Per docs:
http://postgis.net/docs/ST_Distance.html
"..For geography type defaults to return spheroidal minimum distance
between two geographies in meters.
..For geography type defaults to return the minimum distance around WGS 84
spheroid between two geographies in meters. Pass in false to return answer
in sphere instead of spheroid."
Test:
select ST_Distance(ST_SetSRID(ST_MakePoint(-73.9662500, 40.7834300),
4326), ST_SetSRID(ST_MakePoint(-74.1960983, 40.739418), 4326));
-- output (looks like a bug): 0.234024137979163
4326), ST_SetSRID(ST_MakePoint(-74.1960983, 40.739418), 4326), false);
-- output: 19967.534156972
4326), ST_SetSRID(ST_MakePoint(-74.1960983, 40.739418), 4326), true);
-- output: 20013.836017253
Env:
Win 8.1
pgAdmin III v1.18.1
PostgreSQL 9.3.5, compiled by Visual C++ build 1600, 64-bit (EDB)
POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2965>
