[postgis-tickets] [PostGIS] #2980: directional as a street name should not be abbreviated
trac at osgeo.org
Sat Oct 25 03:58:37 PDT 2014
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: pagc_address_parser | Version: trunk
Keywords: |
Comment(by robe):
Doing this seems to do the trick though need to test some more before I
commit.
-- define NORTH and SOUTH as regular words
INSERT INTO pagc_lex(seq, word, stdword, token, is_custom)
SELECT seq, word, stdword, token, false
FROM (VALUES ( 2, 'NORTH', 'NORTH', 1),
(2, 'SOUTH', 'SOUTH', 1) ) As f(seq,word,stdword,token);
-- now that we have north and south are regular words if they are seen
with
-- an additional word we want it treated as directional token
(unfortunately the
-- word token ranks higher causing this one to always be ignored -- so up
this one
UPDATE pagc_rules SET RULE = '0 22 1 2 -1 1 2 5 6 -1 1 17' WHERE rule = '0
22 1 2 -1 1 2 5 6 -1 1 16';
-- may want to consider lowering the 0 1 2 -1 1 5 6 -1 1 rule -
So after the above change I have:
{{{SELECT predirabbrev, streetname, streettypeabbrev
FROM pagc_normalize_address('41 north st, boston, ma 02109');
predirabbrev | streetname | streettypeabbrev
| NORTH | ST
N | WASHINGTON | ST
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2980#comment:2>
