[postgis-tickets] [PostGIS] #3226: interrupt relate regress fails on PostgreSQL 9.5
PostGIS trac at osgeo.org
Sun Aug 2 20:34:40 PDT 2015
 Reporter:  robe     |      Owner:  strk
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.2.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
  interrupt_relate .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_105_diff)
 --- interrupt_relate_expected   2014-11-15 20:10:13.000000000 -0800
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_105_out
 2015-07-31 16:49:09.000000000 -0700
 @@ -6,7 +6,7 @@
  coveredby interrupted on time
  ERROR:  canceling statement due to statement timeout
  crosses interrupted on time
 -ERROR:  canceling statement due to statement timeout
 +t
 I accidentally left the interrupt tests enabled on the run that debbie
 does to test out PostgreSQL Git changes.  Looks like something changed in
 the output (not sure what that extra t is for), that is causing the
 interrupt_relate to consistently fail.
 This started failing July 31st consistently.  Can't see anything we
 changed or that changed in postgresql that would cause this change so a
 bit puzzled.
 the postgres commit that triggered the run was this:
 http://debbie.postgis.net:8080/job/PG_Version_9.5_Git/77/changes#detail0
 which corresponds to this:
 https://github.com/postgres/postgres/commit/edf26ed033f18bddc9bfe5c239388330150766a1
 but in that period (there were also a ton of PostGIS changes)
 up thru r13865
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3226>
