[postgis-tickets] [PostGIS] #3223: Add memcmp short-circuit to ST_Equals
trac at osgeo.org
Tue Aug 4 02:23:01 PDT 2015
Reporter: dbaston | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: reopened => closed
* resolution: => fixed
Comment:
Closing, after confirming that the interrupt tests only failed because the
ST_Equals call performed by the test is now faster than the timeout. Case
fixed by changing the testcase to make not as easy to compute equals :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3223#comment:5>
