[postgis-tickets] [PostGIS] #3206: winnie crashing with topology ST_AddModeFace in C commit 9.3 w32 bit run
trac at osgeo.org
Tue Aug 4 14:58:36 PDT 2015
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by robe):
doesn't work. tried on my machine and get
lwgeom_topo.c:33:24: error: expected ')' before 'd'
# define LWTFMT_ELEMID d
lwgeom_topo.c:597:64: note: in expansion of macro 'LWTFMT_ELEMID'
lwerror("SQL/MM Spatial exception - coincident edge %"
LWTFMT_ELEMID,
lwgeom_topo.c:612:66: note: in expansion of macro 'LWTFMT_ELEMID'
lwerror("Spatial exception - geometry intersects edge %"
LWTFMT_ELEMID,
lwgeom_topo.c:628:17: note: in expansion of macro 'LWTFMT_ELEMID'
LWTFMT_ELEMID, edge->edge_id);
lwgeom_topo.c: In function '_lwt_FindAdjacentEdges':
lwgeom_topo.c:1257:44: note: in expansion of macro 'LWTFMT_ELEMID'
lwerror("corrupted topology: edge %" LWTFMT_ELEMID
lwgeom_topo.c:1384:54: note: in expansion of macro 'LWTFMT_ELEMID'
lwerror("Corrupted topology: adjacent edges %" LWTFMT_ELEMID " and
%" LWTFMT_ELEMID
lwgeom_topo.c: In function '_lwt_AddFaceSplit':
lwgeom_topo.c:1472:55: note: in expansion of macro 'LWTFMT_ELEMID'
lwerror("Backend error (no ring edges for edge %" LWTFMT_ELEMID "):
%s",
lwgeom_topo.c: In function '_lwt_AddEdge':
lwgeom_topo.c:2073:41: note: in expansion of macro 'LWTFMT_ELEMID'
" (endnodes in faces %" LWTFMT_ELEMID " and %"
LWTFMT_ELEMID ")",
lwgeom_topo.c:2200:22: note: in expansion of macro 'LWTFMT_ELEMID'
lwerror("Left(%" LWTFMT_ELEMID ")/right(%" LWTFMT_ELEMID ")"
Makefile:187: recipe for target `lwgeom_topo.lo' failed
make[1]: *** [lwgeom_topo.lo] Error 1
make[1]: Leaving directory `/projects/postgis/branches/winnie/liblwgeom'
GNUmakefile:14: recipe for target `all' failed
make: *** [all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3206#comment:35>
