[postgis-tickets] [PostGIS] #3229: redefined warning notice
    trac at osgeo.org
    Tue Aug  4 15:48:20 PDT 2015
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Description changed by robe:
Old description:
> -I/projects/CGAL/rel-sfcgal-1.1.0w64gcc48/include -DHAVE_SFCGAL
> -I/projects/json-c/rel-0.12w64gcc48/include
> -I/projects/pcre/rel-8.33w64gcc48/include
> -I/projects/postgresql/rel/pg9.4w64gcc48/include -I/projects/rel-
> libiconv-1.13.1w64gcc48/include -fPIC -I/projects/CGAL/rel-
> sfcgal-1.1.0w64gcc48/include -DHAVE_SFCGAL -I. -I./
> -Ie:/jenkins/postgresql/rel/pg9.4w64gcc48/include/server
> -Ie:/jenkins/postgresql/rel/pg9.4w64gcc48/include/internal
> -I./src/include/port/win32 -DEXEC_BACKEND -I/projects/libxml/rel-
> libxml2-2.7.8w64gcc48/include/libxml2  "-I/src/include/port/win32"
> -Ie:/jenkins/postgresql/rel/pg9.4w64gcc48/include/server/port/win32  -c
> -o postgis_topology.o postgis_topology.c
> postgis_topology.c:1:0: warning: -fPIC ignored for target (all code is
> position independent) [enabled by default]
> postgis_topology.c:26:0: warning: "POSTGIS_DEBUG_LEVEL" redefined
>  #define POSTGIS_DEBUG_LEVEL 1
> In file included from postgis_topology.c:22:0:
> ../postgis_config.h:123:0: note: this is the location of the previous
> definition
>  #define POSTGIS_DEBUG_LEVEL 0
> gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
> statement -Wendif-labels -Wmissing-format-attribute -Wformat-
New description:
 -Ie:/jenkins/postgresql/rel/pg9.4w64gcc48/include/server/port/win32  -c -o
 postgis_topology.c:26:0: warning: "POSTGIS_DEBUG_LEVEL" redefined [enabled
 by default]
 definition
 shows up on both debbie and winnie
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3229#comment:1>
