[postgis-tickets] [PostGIS] #3235: postgis_upgrade.sql is not a single transaction
trac at osgeo.org
Mon Aug 10 13:46:56 PDT 2015
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
I noticed that the "attempt to redefine poarameter 'postgis.backend'"
error (#2382) did not prevent some DROPS from happening. Paul confirmed.
There's some drop_after or more that is run despite errors in the upgrade
procedure.
Upgrades should be a single transaction.
This is upgrading to 2.2, I hadn't tested upgrading to 2.1 or 2.0.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3235>
