[postgis-tickets] [PostGIS] #3227: Support for Tiger 2015
trac at osgeo.org
Sat Aug 15 18:51:29 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: reopened
Priority: high | Milestone: PostGIS 2.2.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Brian the create_geogcode.sql runs the normalize_address install in
addition to other things. Are you all set with that. Wasn't clear from
above.
I committed changes at r13907 to address some of the issues you raised.
Also changed the default paths for sh to be those of ubuntu/debian. I
figure a large majority of Linux users are Ubuntu these days so might as
well pattern after that. Eventually I might just add more profiles for
different OS since the whole OS thing is a misnomer, and may add windows
powershell for those who prefer to use that over standard windows dos
shell.
I'm going to spin up my test Ubuntu server and try to test on that before
release.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3227#comment:6>
