[postgis-tickets] [PostGIS] #3238: SFCGAL tests failing
PostGIS trac at osgeo.org
Sun Aug 16 03:05:35 PDT 2015
  Reporter:  strk     |      Owner:  colivier
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  sfcgal   |    Version:  trunk
Resolution:           |   Keywords:  testsing
Comment (by strk):
 Another example:
  sfcgal/wmsservers .. failed (diff expected obtained:
 /tmp/pgis_reg/test_119_diff)
 --- sfcgal/wmsservers_expected  2015-08-07 18:03:35.319818195 +0200
 +++ /tmp/pgis_reg/test_119_out  2015-08-16 12:03:15.110438037 +0200
 @@ -1,5 +1,6 @@
  Starting up MapServer/Geoserver tests...
  Setting up the data table...
 +WARNING:  'postgis.backend' is currently set to 'sfcgal' and cannot be
 changed until you reconnect at character 39
  Running Geoserver 2.0 NG tests...
  Geoserver1|POLYGON
  Geoserver2|4326
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3238#comment:1>
