[postgis-tickets] [PostGIS] #3227: Support for Tiger 2015
trac at osgeo.org
Sun Aug 16 17:27:01 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: reopened
Priority: high | Milestone: PostGIS 2.2.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment (by darkblueb):
hmm problems .. here is '''SETUP'''
user at debian8:/home/shared/srcs_db8/postgis_trunk$ svn up
Updating '.':
G extras/tiger_geocoder/tiger_loader_2015.sql
Updated to revision 13913.
user at debian8:/home/shared/srcs_db8/postgis_trunk$ make distclean
CFLAGS='-g -O0' CXXFLAGS='-g -O0' ./configure --enable-profile --enable-
debug
make && sudo make install
shell$ createdb tl_test_ext ; psql tl_test_ext
tl_test_ext=# create extension postgis;
tl_test_ext=# create extension address_standardizer;
tl_test_ext=# create extension address_standardizer_data_us ;
tl_test_ext=# create extension fuzzystrmatch ;
tl_test_ext=# create extension postgis_tiger_geocoder;
tl_test_ext=# SELECT na.address, na.streetname,na.streettypeabbrev, na.zip
tl_test_ext-# FROM normalize_address('1 Devonshire Place, Boston, MA
02109') AS na;
address | streetname | streettypeabbrev | zip
1 | Devonshire | Pl | 02109
(1 row)
tl_test_ext=# SELECT Loader_Generate_Nation_Script('sh');
here is '''RESULT'''
execute loader script line by line.. gets a few lines down then stuck...
user at debian8:/gisdata/temp$ ls
tl_2015_us_state.cpg tl_2015_us_state.prj
tl_2015_us_state.shp.ea.iso.xml tl_2015_us_state.shp.xml
tl_2015_us_state.dbf tl_2015_us_state.shp tl_2015_us_state.shp.iso.xml
tl_2015_us_state.shx
user at debian8:/gisdata/temp$ ${PSQL} -c "CREATE TABLE
tiger_data.state_all(CONSTRAINT pk_state_all PRIMARY KEY
(statefp),CONSTRAINT uidx_state_all_stusps UNIQUE (stusps), CONSTRAINT
uidx_state_all_gid UNIQUE (gid) ) INHERITS(tiger.state); "
CREATE TABLE
user at debian8:/gisdata/temp$ ${SHP2PGSQL} -D -c -s 4269 -g the_geom -W
"latin1" tl_2015_us_state.dbf tiger_staging.state | ${PSQL}
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
SET
SET
BEGIN
CREATE TABLE
ALTER TABLE
addgeometrycolumn
tiger_staging.state.the_geom SRID:4269 TYPE:MULTIPOLYGON DIMS:2
(1 row)
ERROR: value too long for type character varying(2)
CONTEXT: COPY state, line 1, column region: " [shp2pgsql-
core.c:FindPolygons:567] FindPolygons[0]: allocated space for 1 rings"
ROLLBACK
ERROR: relation "tiger_staging.state" does not exist
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3227#comment:13>
