[postgis-tickets] [PostGIS] #3227: Support for Tiger 2015
trac at osgeo.org
Mon Aug 17 01:11:40 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: reopened
Priority: high | Milestone: PostGIS 2.2.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Hmm do you have debugging enabled in your postgis build -- what's this
that shows on your code:
[shp2pgsql-core.c:FindPolygons:567] FindPolygons[0]: allocated space for 1
rings"
Looks like it's echoing debug statements which perhaps are getting in the
way of the copy command. I forget when I change from insert to copy mode.
It might have been in 2.2 I suppose. Before they were inserts (which was
much slower)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3227#comment:15>
