[postgis-tickets] [PostGIS] #3239: ST_{Mod, New}EdgeHeal does not check for TopoGeometry defined by removed node
trac at osgeo.org
Mon Aug 17 03:40:18 PDT 2015
#3239: ST_{Mod,New}EdgeHeal does not check for TopoGeometry defined by removed
node
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: topology | Version: 2.1.x
Keywords: |
Reading the code I don't think we're checking for the node being removed
by edge healing operations to be used in the definition of a TopoGeometry.
We should !
This is to be checked first, but pretty sure it's the case.
NOTE: there's no 2.2.1 milestone to assign to tickets.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3239>
