[postgis-tickets] [PostGIS] #2316: Setup buildbot jobs to test sfcgal
PostGIS trac at osgeo.org
Mon Aug 17 17:01:19 PDT 2015
  Reporter:  robe       |      Owner:  robe
      Type:  task       |     Status:  new
  Priority:  high       |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 Sadly this did not work.  I think I need to upgrade Debbie to a newer
 version of Debian or Ubuntu.  I was planning to build her from scratch or
 another version of her just for testing, but probably won't have time for
 that for a couple of months.
 Reading package lists... Done
 Building dependency tree
 Reading state information... Done
 E: Build-Depends dependency for sfcgal-bin cannot be satisfied because no
 available versions of package debhelper can satisfy version requirements
 root at 30266-3-1329969:~#   apt-get -b source sfcgal-bin
 NOTICE: 'sfcgal-bin' packaging is maintained in the 'Git' version control
 system at:
 git://anonscm.debian.org/pkg-grass/sfcgal.git
 Need to get 2,517 kB of source archives.
 Get:1 http://debian.mirrors.ovh.net/debian/ sid/main sfcgal 1.1.0-2 (dsc)
 [2,153 B]
 Get:2 http://debian.mirrors.ovh.net/debian/ sid/main sfcgal 1.1.0-2 (tar)
 [2,393 kB]
 Get:3 http://debian.mirrors.ovh.net/debian/ sid/main sfcgal 1.1.0-2 (diff)
 [121 kB]
 Fetched 2,517 kB in 2s (1,230 kB/s)
 gpgv: keyblock resource `/root/.gnupg/trustedkeys.gpg': file open error
 gpgv: Signature made Fri 31 Jul 2015 06:27:43 AM PDT using RSA key ID
 E88D4AF1
 gpgv: Can't check signature: public key not found
 dpkg-source: warning: failed to verify signature on ./sfcgal_1.1.0-2.dsc
 dpkg-source: info: extracting sfcgal in sfcgal-1.1.0
 dpkg-source: info: unpacking sfcgal_1.1.0.orig.tar.gz
 dpkg-source: info: unpacking sfcgal_1.1.0-2.debian.tar.xz
 dpkg-source: info: applying 0001-Fix-spelling-errors-accourding-to-
 lintian-tool-of-th.patch
 dpkg-buildpackage: export CFLAGS from dpkg-buildflags (origin: vendor): -g
 -O2
 dpkg-buildpackage: export CPPFLAGS from dpkg-buildflags (origin: vendor):
 dpkg-buildpackage: export CXXFLAGS from dpkg-buildflags (origin: vendor):
 -g -O2
 dpkg-buildpackage: export FFLAGS from dpkg-buildflags (origin: vendor): -g
 -O2
 dpkg-buildpackage: export LDFLAGS from dpkg-buildflags (origin: vendor):
 dpkg-buildpackage: source package sfcgal
 dpkg-buildpackage: source version 1.1.0-2
 dpkg-buildpackage: source changed by Sven Geggus <sven-debian at geggus.net>
 dpkg-buildpackage: host architecture amd64
  dpkg-source --before-build sfcgal-1.1.0
 dpkg-checkbuilddeps: Unmet build dependencies: debhelper (>= 9) libcgal-
 dev libboost-all-dev libmpfr-dev libgmp-dev libopenscenegraph-dev
 libopenthreads-dev libpq-dev libqt4-dev libqt4-opengl-dev pkg-kde-tools
 dpkg-buildpackage: warning: Build dependencies/conflicts unsatisfied;
 aborting.
 dpkg-buildpackage: warning: (Use -d flag to override.)
 Build command 'cd sfcgal-1.1.0 && dpkg-buildpackage -b -uc' failed.
 when I try to install the missing dependencies I get:
  apt-get install libcgal-dev libboost-all-dev libmpfr-dev libgmp-dev
 libopenscenegraph-dev libopenthreads-dev libpq-dev libqt4-dev libqt4
 Package libcgal-dev is not available, but is referred to by another
 package.
 This may mean that the package is missing, has been obsoleted, or
 is only available from another source
 E: Package 'libcgal-dev' has no installation candidate
 E: Unable to locate package libgmp-dev
 FWIW debbie is running:
 Distributor ID: Debian
 Description:    Debian GNU/Linux 6.0.10 (squeeze)
 Release:        6.0.10
 Codename:       squeeze
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2316#comment:9>
