[postgis-tickets] [PostGIS] #3241: Wrong phrase in the documentation of GetEdgeByNode topology function
trac at osgeo.org
Tue Aug 18 04:52:36 PDT 2015
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: topology | Version: 2.1.x
Keywords: |
In the
[http://www.postgis.net/docs/manual-2.1/GetEdgeByPoint.html]
The phrase
If the point is the location of a node, then an exception is thrown. To
avoid this run the GetNodeByPoint function.
Should be removed.
Infact the function correctly dont raise an exception if the point is a
node for an edge, but only if the point is node for two or more edges.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3241>
