[postgis-tickets] [PostGIS] #3242: Segfault in Jenkins 2.0 test run
trac at osgeo.org
Tue Aug 18 04:59:59 PDT 2015
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.8
Component: raster | Version: 2.0.x
Keywords: |
See http://debbie.postgis.net:8080/job/PostGIS_Regress/7553/console
Extract:
PostgreSQL 8.4.17 on x86_64-unknown-linux-gnu, compiled by GCC gcc
(Debian 4.4.5-8) 4.4.5, 64-bit
Postgis 2.0.8SVN - r13922 - 2015-08-18 10:14:52
GEOS: 3.4.3dev-CAPI-1.8.3 r4073
PROJ: Rel. 4.7.1, 23 September 2009
make[3]: Entering directory
`/var/lib/jenkins/workspace/postgis/branches/2.0/raster/test/core'
gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../../rt_core
-I../../../liblwgeom -I/var/lib/jenkins/workspace/gdal/rel-2.0w64/include
-I/var/lib/jenkins/workspace/geos/rel-3.4.3devw64/include -c testapi.c
mode=link gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
-I../../rt_core -I../../../liblwgeom
-I/var/lib/jenkins/workspace/geos/rel-3.4.3devw64/include testapi.o
../../rt_core/librtcore.a ../../rt_core/librtcore.a
../../../liblwgeom/.libs/liblwgeom.a
-L/var/lib/jenkins/workspace/gdal/rel-2.0w64/lib -lgdal
-L/var/lib/jenkins/workspace/geos/rel-3.4.3devw64/lib -lgeos_c -lm -o
testapi
-I/var/lib/jenkins/workspace/geos/rel-3.4.3devw64/include -c testwkb.c
-I/var/lib/jenkins/workspace/geos/rel-3.4.3devw64/include testwkb.o
testwkb
./testapi
Warning 6: PNG driver doesn't support data type Int16. Only eight bit
(Byte) and sixteen bit (UInt16) bands supported. Defaulting to Byte
make[3]: *** [check] Segmentation fault
make[3]: Leaving directory
Is it normal that raster tests are run while GDAL isn't being reported by
run_test.pl ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3242>
