[postgis-tickets] [PostGIS] #3238: SFCGAL tests failing
PostGIS trac at osgeo.org
Tue Aug 18 09:51:01 PDT 2015
  Reporter:  strk     |      Owner:  colivier
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  sfcgal   |    Version:  trunk
Resolution:           |   Keywords:  testsing
Comment (by pramsey):
 You can change the value, but if the callback is wrong you won't change
 the handler, so things are even more terrible, in that your GUC will say
 "sfcgal" but the actual handler will still be delegating to geos.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3238#comment:9>
