[postgis-tickets] [PostGIS] #3238: SFCGAL tests failing
trac at osgeo.org
Wed Aug 19 07:08:07 PDT 2015
Reporter: strk | Owner: colivier
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.2.0
Component: sfcgal | Version: trunk
Resolution: fixed | Keywords: testsing
Comment (by pramsey):
If the warning is an error it makes "ALTER EXTENSION ... UPDATE TO"
unusable except in the case where it's the very first thing you call after
connecting.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3238#comment:16>
