[postgis-tickets] [PostGIS] #2291: &&& can't be upgraded from 2.0 to 2.1
PostGIS trac at osgeo.org
Wed Aug 19 10:43:56 PDT 2015
  Reporter:  robe                   |      Owner:  pramsey
      Type:  defect                 |     Status:  closed
  Priority:  high                   |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  invalid                |   Keywords:  operator
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Unless someone can provide a SQL script that demonstrates the issue, I'm
 closing this. I just did an upgrade w/ no problem, on a database with an
 existing ND index, so...?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2291#comment:9>
