[postgis-tickets] [PostGIS] #2422: geography regression difference ST_DWithin
PostGIS trac at osgeo.org
Thu Aug 20 11:22:47 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  2.1.x
Resolution:  fixed    |   Keywords:
Comment (by robe):
 regression failure on winnie:
  geography .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0_gdal2.0w64/test_38_diff)
 --- geography_expected  2015-08-20 14:19:09 -0400
 +++ /projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0_gdal2.0w64/test_38_out
 2015-08-20 14:22:07 -0400
 @@ -21,9 +21,9 @@
  geog_precision_pazafir|0|0
  1|MULTILINESTRING((0 0,1 1))
 -#2422|2|1609|t|t|1005.62727977|1006.24818105|1005.62727976958|1005.62727976958
 -#2422|2|1600|t|t|1005.62727977|1006.24818105|1005.62727976958|1005.62727976958
 -#2422|2|1068|t|t|1005.62727977|1006.24818105|1005.62727976958|1005.62727976958
 +#2422|2|1609|t|t|1005.62727977|1006.24818105|1005.62727976922|1005.62727976922
 +#2422|2|1600|t|t|1005.62727977|1006.24818105|1005.62727976922|1005.62727976922
 +#2422|2|1068|t|t|1005.62727977|1006.24818105|1005.62727976922|1005.62727976922
 #2422|1|1609|t|t|1400.23034685|1396.81609491|1400.23034684753|1400.23034684753
 #2422|1|1600|t|t|1400.23034685|1396.81609491|1400.23034684753|1400.23034684753
 #2422|1|1068|f|f|1400.23034685|1396.81609491|1400.23034684753|1400.23034684753
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2422#comment:44>
